Overheating???
Old Jul 28, 2009 | 10:15 AM
Ragelite's Avatar
It did boil over the other night when I got home. Im going to run the same trail tonight and come home and leave the bike on and let the fan run till it shuts off then Ill shut the bike off and then turn it back on and see if it happens.
Old Jul 28, 2009 | 10:20 AM
TLC's Avatar
TLC
Maybe you just need to bleed your coolant system,you may have a air lock in there.
Old Jul 28, 2009 | 10:47 AM
Ragelite's Avatar
Bleed it? Ive never done that before. lol is there a simple way of doing it? I still hope that the carb isnt the problem, like I said it started after I cleaned it.
Old Jul 28, 2009 | 11:14 AM
TLC's Avatar
TLC
Here is a post about it. http://forums.atvconnection.com/pola...sportsman.html
Old Jul 28, 2009 | 11:49 AM
  #15
Ragelite's Avatar
Ill try this tonight and if it doesn't work then Im taking the carb back off the bike.
Thanks again guys for all the info!
....if its low can I use reg coolant? or do I have to get Polaris coolant?
Old Jul 28, 2009 | 12:26 PM
  #16
Ragelite's Avatar
Is there a bleeder screw?
Old Jul 28, 2009 | 12:31 PM
  #17
Ragelite's Avatar
Air fuel mixture screw? a guy is telling me maybe I changed that when I cleaned the carb but I dont remember touching it. Can someone tell me what the setting is for that so I can check it?
Thanks
Old Jul 28, 2009 | 06:11 PM
  #18
Kerbbirds's Avatar
That screw with the spring on it in the bottom of the carb is the fuel screw, should be set at 2.5 turns out.
Old Jul 29, 2009 | 05:41 AM
  #19
Ragelite's Avatar
Which it wasnt but it is now that I have taken the carb back out, but now I have fuel leaking when I rev it hard, looks like there is a small tit that comes off the bottom of the carb and thats where its coming from...
Jenn1
Sep 8, 2015 09:16 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
cornermike
Jul 30, 2015 06:37 AM
