Crooked rear end!!!! HELP!!!! Scramler 500 4x4
Old Aug 4, 2009 | 08:15 PM
tandtprine's Avatar
Default Crooked rear end!!!! HELP!!!! Scramler 500 4x4
Ok... I completely redid the eccentric... after the guy before me blew out a bearing.
It was sitting crooked when I started.... i thought it was because the axle had wallered out the eccentric.
Well, now it is still sitting crooked.
The right wheel sits a little farther forward than the left.
Don't see any apparent frame issues.
Any ideas??
Old Aug 5, 2009 | 11:24 AM
tandtprine's Avatar
The axle was not bent when I pulled it out....
Could the swing arm bushings be causing the problem if they had "wallered" also???
Old Aug 5, 2009 | 05:14 PM
Polarat's Avatar
I would think the swing arm bushings would feel loose if they were wallered. Does the axle look like it sits level by looking at it from the back? The housing mounts might be a little bent.
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
