Need Answer Fast!!
Old Aug 12, 2009 | 10:30 AM
gordster1122's Avatar
Default Need Answer Fast!!
last night i was driving my 850 XP and this morning i tryed to start it and it just makes a clicking noise was runnning perfect last night anyone know the problem?
Old Aug 12, 2009 | 12:28 PM
200es's Avatar
sounds like a bad soloid try pull starting it if it starts then thats probely your problem
Old Aug 12, 2009 | 01:21 PM
HawkeyeRider's Avatar
You can also check the battery terminals to make sure they are tight, one might have loosened up.
Old Aug 12, 2009 | 03:21 PM
HIGHOCTANE's Avatar
Check battery connections,if they are tight check battery voltage..if the starter isn't getting enough current the solenoid will just click.
200es..the 850 doesn't have a recoil starter.
Old Aug 12, 2009 | 03:52 PM
bitterfitter's Avatar
No pull starer on an 850XP, and i wouldn't want to try if there was one.
Old Aug 12, 2009 | 04:13 PM
i'll check the connections when i get home and i charged the battery and its good but still making the clicking noise and my cousin who works at a dealer said they had a 850 XP there and after 100 miles the starter went lol hope my didnt go either but i will post when i get home
Old Aug 27, 2009 | 04:19 PM
just cleaned the battery connections this monring and still clicking?
Old Aug 27, 2009 | 05:49 PM
chuck_raduenz's Avatar
short the 2 solinoid posts out. see if it starts that way. if no go on that is the starter. or you could take a test light and check for power on both sids of the solinid.
Old Aug 27, 2009 | 06:27 PM
700 sportsman's Avatar
Yeh, I would try to jumper "short" the solenoid like chuck said, and If is fires up, you've found your problem, also I have the service manual for you bike, if you want it shoot me PM
Old Aug 27, 2009 | 07:39 PM
can you guys tell me how to do it?
