oem wheel vs. aftermarket
Old Aug 12, 2009 | 01:40 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Default oem wheel vs. aftermarket
Hey guy's, I was wondering just how much weight difference there is from a stock 12" steel wheel to lets say a 12" aluminum. And would I see any benefits swithing to aluminum over steel, other than just looking alot nicer.
Old Aug 12, 2009 | 02:35 PM
700 sportsman's Avatar
I'd say your best bet would be to look on the manufacturer website, because there will be so many different numbers, between the manufacturers, and the different styles of wheels that are available
Old Aug 13, 2009 | 08:18 AM
switzomatic's Avatar
Default Wheels
Aluminum rims are lighter. The benefit you gain from that is less weight for the machine to turn so you basically use less to get more. Won't see hp or top end difference(on a stock machine) but will make life easier on your drivetrain/belt. Thus the switch that many are making to 14" rims which gives you more rim and a lot less tire. Just ordered a set myself and am looking forward to seeing how much of a difference there is.
fd24
Jan 16, 2019 08:59 AM
meddy0388
Sep 9, 2015 06:41 AM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
Jason Campbell
Sep 7, 2015 02:25 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
