Bendix question
Old Aug 18, 2009 | 06:20 AM
jbrooks22's Avatar
Default Bendix question
I am curious, if the Bendix is sticking or stuck would that make it impossible to use the recoil starter. Since the Recoil is bolted back on the spring works fine but it still will not budge unless the recoil is off. Once I take the recoil off I can turn the crank by hand but the little gear on the side which I believe is the bendix is just sitting there. on the bottom left.
Old Aug 18, 2009 | 08:09 AM
midnightxplorer's Avatar
Well try this, pull it over and see if they bendix stays engaged or not, chances are it will release....if it wont take your recoil cover off and remove it.
Old Aug 18, 2009 | 11:54 AM
eggenz7's Avatar
are you puttin the loose end of the bendix back into the bushing on the recoil housing? maybe its not getting in there and causing things to bind up.
i would also say just remove the bendix if its stuck open so it doesnt end up turning the starter motor continuously.
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Alex G.
Sep 11, 2017 11:38 PM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
Jackg17
Sep 26, 2015 09:30 PM
