Tire / rim suggestions/
Old Sep 1, 2009 | 11:23 PM
gdo's Avatar
gdo
Default Tire / rim suggestions/
01 Sportsman 500HO. I have Bighorns on front. With 10 in stock rims on back, no Bighorns available as I understand it. Recommend a tire comparable to Bighorns that will fit? Or should I change rims (don't ant expensive alloys). Thanks
Old Sep 2, 2009 | 07:02 AM
switzomatic's Avatar
Default Tires
If you are looking for tires/rims cheap check out ebay or craigslist. Chances are you can find a set of stock Polaris PXT tires on steel rims(12"-same bolt pattern as your machine). Just sold mine complete for $300 +shipping.
Old Sep 2, 2009 | 07:05 AM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Are your stock wheels steel? If so I would'nt think it would be to much trouble to find a couple of steel to match the fronts. My 02 magnum came stock with 12" steel wheels front and rear but if you look up specs. on my model it shows a 10" rear wheel. Go figure? Anyways if you could find some 12" to fit, it would give you many more tire options.
Old Sep 2, 2009 | 07:31 AM
Roofer's Avatar
Doesn't care what people ride as long as they can keep up!
I had that problem with the Xplorer 400's I had. Just look for some 12x7 wheels with a 4/4 pattern. I found a set for $50 one time and they were aluminum.
Old Sep 2, 2009 | 10:10 AM
gdo's Avatar
gdo
Thanks guys--I was looking at the ITP steel wheels...of course that means buying a set of 4. Understand my rears are 10x7s?
Also--what about tire suggestions if I just keep the stock 10" wheels?
Old Sep 2, 2009 | 08:01 PM
Roofer's Avatar
You don't necessarily have to buy 4 wheels. I never did, but I didn't care what they looked like. The tires are what gave me the performance.
One tire you could look at is the tri-claws. Very good tire for all terrains. I think you can get them in 13.5" wide on the rear. I don't think the Bi-claws for the front will fit with stock wheels though.
Old Sep 3, 2009 | 11:28 AM
gdo's Avatar
gdo
I will research hat recommendation. Any thoughts on Vampires? (tires, that is ;-)
Old Sep 3, 2009 | 07:56 PM
The vampires are a decent tire but a little heavy for my taste. Buddy has them on his 700 and gets along pretty good in the thick stuff. BUT! He 's also broken a few things in the drive line thanks to those babys. When they hook up, they really hook up! Maybe it's just his riding style. I don't know. I'm very content with the mudlite's XL, good bite, light weight for a mud tire and not lugging you down.
Old Sep 3, 2009 | 08:21 PM
Roofer's Avatar
vamps are great for the mud, but yes, they are heavy tires. Much better tires on the market now, IMO.
Old Sep 3, 2009 | 10:31 PM
gdo's Avatar
gdo
How about maxxis mud bugs on the rear...
