Stone punctured aluminum rim
Old Oct 2, 2009 | 07:43 PM
09 popo HO's Avatar
Default Stone punctured aluminum rim
long story short: got stuck, lots of big stones in mud, when pulled out i guess a stone got between inside of rim and brakes. it punctured the inside of the rim, No wonder I couldn't find the leak in the tire. a 2 inch slit on the inside of my rim, Can I fix it? JB weld or something?
I have never heard of this happening.
I will put up some pics tomorrow. Don't want to buy a new rim right now.
Help please any suggestions.
Old Oct 2, 2009 | 08:09 PM
switzomatic's Avatar
JB Weld won't hold and aluminum is not cheap to get welded. May have to check out ebay or craigslist for an inexpensive replacement.
Old Oct 2, 2009 | 08:22 PM
700 sportsman's Avatar
I bet you could find a replacement fairly cheap, but I'd see about welding it
PS where are you located
Old Oct 2, 2009 | 08:37 PM
09 popo HO's Avatar
new Brunswick, Just outside Fredericton.
Old Oct 2, 2009 | 09:12 PM
O well, I was gunna say if you were close, I could help ya out on the welding
Old Oct 3, 2009 | 12:28 AM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
If it's just a crack/slit it should'nt be a big deal to repair. I would'nt think a welder would charge you more than about $50 Sounds like less than an hour's work at worst. At least that's my rate. I guess it all depends on the going rates in your area.
Old Oct 3, 2009 | 05:25 AM
TLC's Avatar
TLC
I use jb weld on aluminum boats that we put holes into,why would it not work on a rim that just needs to hold 5 psi of air in?
Old Oct 3, 2009 | 07:29 AM
Scooter86's Avatar
Knows Old ATV Questions!
JB weld will probably hold for a while, but it will be susceptible to the same type of damage. I would think getting it welded would be an option, but if you have to remove the tire to do it, just buy another rim.
Old Oct 3, 2009 | 01:06 PM
Mopar__Hemi's Avatar
yeah just buy another rim cause you can get one fairly cheap
Old Oct 3, 2009 | 06:26 PM
09 popo HO's Avatar
here are some pics of the damage.
I just wanna say thanks for all the suggestions. This forum is a wealth of knowledge and helpful people.
I was thinking of calling around on Monday to see if any shops in the area can weld aluminum and what they would charge. I can't see it taking more than 5 minutes to fix if that.
But I will need to remove the tire.
I bought some JB weld so I might try that as well if I have no luck on finding a welder.
I would buy new rims but all the good deals are with free shipping to the states but they charge an arm and leg to ship to Canada.
Any tips on getting the tire off the rim.
