Debris in Oil
Old Oct 21, 2009 | 10:49 AM
DingoNutz's Avatar
Default Debris in Oil
Well, I did a 10 hour break-in oil change last night and to my surprise, when I drained the crackcase, a small 2" piece of what looked like paper came out with the oil. I have no idea what it is and don't know how it got there. Must of been during assembly of the engine I'm guessing. The bike has been running fine. Wondering if I should be concerned or just glad that it's out. I saved the piece in case.
Old Oct 21, 2009 | 10:56 AM
gaspumpcity's Avatar
If its magnetic I would be concerned?
Old Oct 21, 2009 | 11:52 AM
02magnum500's Avatar
Gets his share of deer.
Thats weird. Maybe let the dealer know about it just incase it causes trouble for you down the road? Could it be part of the oil filter, that is the only thing I can think of that is paper in or around the engine????? 2" is a bit big to come out of the filter mesh though.....
Old Oct 21, 2009 | 12:14 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Was there any metal particles in the oil? If not you are OK. I bet it was from the oil filter. I use NAPA Gold (Wix) filters instead of the Polaris brand (a better filter the cost a dollar less.
Old Oct 21, 2009 | 02:15 PM
How could it be from the oil filter when the debris was in the oil pan? Oil from the pan to the oil filter to moving parts then drains back to the pan. Pictures of the finding would be nice.
Old Oct 21, 2009 | 03:01 PM
DingoNutz's Avatar
I did feel some fine metal particles between my fingers when I checked the oil afterwards, but it's my understanding that that is normal during break-in of a new engine. The rings of the piston rubs the cylinder walls due to its honing pattern and some metal fragments rub off as the process of seating the rings against those cylinder walls progresses. As time passes, that seal is made complete and there should be no more metal fragements in future oil changes.
Old Oct 21, 2009 | 03:55 PM
700 sportsman's Avatar
do you have any pics, and as the others said, the small amounts of material is ok, but it's hard to say what you may have found
Old Oct 21, 2009 | 04:04 PM
I have an oil change coming up I will cut the oil filter open a post pictures. My guess its nothing to worry about (paper I mean)
Old Oct 22, 2009 | 09:28 AM
DingoNutz's Avatar
Well I think I got it figured out. I put some paper towel, regular white paper and some other types of material in a container of oil overnight to saturate it in order too compare to the piece in question. From what I can tell, it looks like it might be a small piece of paper towel. Now how that got in there is stumping me? I guess I shouldn't be too concerned because how much damage could really have been done?
Old Oct 22, 2009 | 10:00 AM
popoman's Avatar
did you ever check your oil and clean the dip stick with a paper towel? maybe a chunk caught on there and you didnt realize it.
