Polaris parts
Old Jun 12, 2010 | 01:52 PM
  #21
ftwflh's Avatar
you have PM
Old Jul 1, 2010 | 09:33 AM
  #22
Vetteluvr987's Avatar
Default Clutch
I need a new clutch or to rebuild my old one. Do I need a clutch removal tool? One of the weights is broke and it appears that the race way where it slides is worn pretty bad. Also the bolt that holds the weight is seized in place. I would just buy a new clutch but the price is a bit steep! Any suggestions on the best way to go would be appreciated.
Old Jul 1, 2010 | 05:54 PM
  #23
ftwflh's Avatar
I dont have any spares as of right now.try Ebay.If you dont have EBS any non EBS clutch will Work.If you use the right spring and weights.I do have spare weights.
Old Jul 7, 2010 | 12:33 AM
  #24
codyspratt's Avatar
needing front an rear fender cab,steering shaft,right footwell,speedometer, and a good carb. if you got 1,, thefuzz65@yahoo.com
Old Nov 28, 2010 | 03:21 AM
  #25
azoregon's Avatar
Help!! where and what kind of cooling fluid can I use for a 2006 Polaris sportsman EFI?? can you use any kind or does it have to be Polaris SPECIAL EXPENSIVE BRAND?
Thank you in advance for your help
Old Nov 28, 2010 | 07:36 AM
  #26
ftwflh's Avatar
Use any anti freeze that is compatible with aluminum engines.I use the same thing I use in my truck
Old Feb 28, 2011 | 06:01 AM
  #27
jmg1170's Avatar
Default Parts Request !!
I need a front rack and all that goes with it (IE mounting brackets and such) for a 2002 Polaris Magnum 325 4x4. If you got it, can u email me at jglg@windstream.net
Old Feb 28, 2011 | 06:08 AM
  #28
ftwflh's Avatar
Nothing that new
Old Jun 6, 2011 | 09:30 PM
  #29
Jmuddin284's Avatar
Lookin for an intake boot without any cracks in it for a 400 2smoke.
Old Jun 7, 2011 | 05:59 AM
  #30
ftwflh's Avatar
Remind me this weekend and I will look.
