Snow Plow Cart
Old Dec 26, 2009 | 08:27 AM
icobob's Avatar
Default Snow Plow Cart
I tried doing a search but has anyone built a cart to move their snow plow around in the garage. I am thinking of building one but wanted a few ideas. Anyone?
Old Dec 26, 2009 | 09:12 AM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
I designed a cart for the plow on my truck which I think would work on a smaller scale just fine. I used 4" steel c-channel. It looks alot like the base of a engine stand just a larger scale. The channel is in the upright position so that the blade sets down in it and keeps it on the cart. Pretty basic design and easy to build if you have any welding skills what so-ever. Sorry no pics.
Old Dec 26, 2009 | 09:28 AM
icobob's Avatar
I think that is some what of what I am thinking. Now just got to get the time. Think I already have the supplies. Thanks
Old Dec 26, 2009 | 10:03 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i made wheels for my truck plow that go into the shoe holders and made a movable wheel set up for(like a minie creeper) for my foot. it's a fisher mm2 plow. works prety good and easily made.
Old Dec 26, 2009 | 10:09 AM
icobob's Avatar
I thought about that also but I dont want to have to take stuff off each time because I want it to be a quick process. Because truthfully I dont really need a cart I just want one lol. I think I am just gonna make a T type frame with wheels on it. Oh by the way thinks for the tips on the spring sag. That helped a ton, although I had a heck of a time compressing the springs back in.
Old Dec 26, 2009 | 11:17 AM
chuck_raduenz's Avatar
make it a triangle. c-chan in front. where the wear bar will sit in like said above. add a wheele to each side of that. then at the back add a swivel wheel where the push tube sits. so all youd need for steel is a c-chan a bit wider than your plow. 2 round bars for axels. weld that under the c-chan. wheels to put on the axels. pins to hold the wheels on. then square tubeing or what ever you have to finish the other 2 sides of the triangle. add a swivel wheel to the point. and your done.
Old Dec 26, 2009 | 11:55 AM
This would work out for you. Just stand the plow up on its blade. Hardwood Furniture Moving Dolly — 600-Lb. Capacity | Dollies | Northern Tool + Equipment
Old Dec 26, 2009 | 01:37 PM
mdvctry's Avatar
Default Hardwood moving dolly
That's what I did also. I found the dolly for $12 bucks, stood the blade flat on it and it works great.
Old Dec 26, 2009 | 06:45 PM
icobob's Avatar
Yea. Dont think it gets much easier than that. May just go and get me one of those dollies. Thanks guys
Old Dec 28, 2009 | 06:58 AM
noooooo's Avatar
The dollies work like a champ. If you get the larger size you can lay it flat on the pushtube. The smaller one is good if you put the blade down and pushtubes up.
shimanok2
Jan 29, 2016 07:37 PM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
stcspiderman
Sep 13, 2015 05:15 PM
ylomnstr
Sep 10, 2015 06:45 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
