Scrambler carb
Old Jan 16, 2010 | 05:34 PM
rkuhnjr's Avatar
Default Scrambler carb
Anyone know the Carb Make/Model on the 09 scrambler 500 ho? (pretty sure it would be the same on a sportsman 500 ho)
I want to get a high altitude jet for it
Old Jan 16, 2010 | 07:16 PM
Mikuni BST 40 is on the the Scrambler with a stock 155 main jet. The Sportsman is basically the same carb with different internals such as a stock main jet of 152.5 Jetting depends on altitude (8,000 ft,10,000 ft 13,000?? Ask a dealer what jetting you need who is in the area you want to go. OPT
Old Jan 16, 2010 | 09:21 PM
rkuhnjr's Avatar
8-10k is what I need to jet it for.
I talked with the dealers and they want $80 to jet it so ima do it myself.
I also need to adjust the clutch to accomodate the jet and altitude but not sure what clutch kit I would need.
both together the dealer quoted me about $300 which is more then i have right now but I need to do it so decided to do it as a DIY project.
Old Jan 16, 2010 | 10:52 PM
rkuhnjr's Avatar
Found this interesting site with this graph below.
Mikuni carburetor operation and tuning
So according to this im looking at about a 135-140 jet for 8000ft
Old Jan 17, 2010 | 09:36 AM
ftwflh's Avatar
here is the factory settings for high altitude jetting 6000ft+ @ 40degree+ 152.5
6000ft+ @40degree and colder 147.5
Clutching @6000+ change weights to 10RH from 10WH.Find them used on Ebay
Old Jan 19, 2010 | 11:23 PM
rkuhnjr's Avatar
those 10-rh weights are hard to find.
I put in a call to my local dealers but they are about as useless as **** on a nun...
Thanks for the numbers though, at least now i know what to look for.
Old Jan 20, 2010 | 11:07 PM
rkuhnjr's Avatar
Do you happen to know the weight of the 10-RH weights?
Looks ill have to go after market brand.
Cole Hadden
Jun 15, 2025 09:05 AM
1000gade
Jul 16, 2015 10:48 AM
maxjung
Jul 15, 2015 11:59 PM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 13, 2015 05:11 PM
