Sportsman xp Bumper mount winch
I would say that with that mount you are asking for big trouble.
If you look behing that bumper you will see all you are attached to is a small aluminum tubing, which is not strong enough for pulling anything. Please check it out before going any further.
Hi, the aluminum tube is quite thick, I have used it about 6-7 times pulling out of the ice on the river my concern is not to pull to the side , I also replaced the self taping bolts that hold the bumper on with bolts with washers and nuts. I'll post if I have a problem with it but so far so good.
Hi, I don't think it will, the radiator is not tight up against the grill, it is angled back and has plenty of room around it plus the fan to cool it. I'm really suprised that Polaris does'nt offer one it would be a great accessory, really who wants there winch 15" off the ground if you run in any mud or wet conditions. Paulmn.
i dont think its gona over heat. as the winch on the 98-04ish yrs covered the radiator. it wasent right up tight. but it still covered the grill.
Before I drop into something deep, I pull a section of the winch cable up tight into my front box. This way I can just reach up and huck it to "land". I throw the drive switch before going in as well. One needs to make sure the rope does not come loose and get wrapped into the front drive shafts.
