carb backfire
Old Jan 17, 2010 | 08:42 PM
odie22's Avatar
Default carb backfire
i went out today and for some reason the carb when to backfireing and its also down on power
Old Jan 17, 2010 | 08:45 PM
fetters's Avatar
check main jet and slow jet for dirt
Old Jan 17, 2010 | 09:00 PM
odie22's Avatar
do you have a link on the carb diagram
Old Jan 17, 2010 | 09:20 PM
ctdnwakulla's Avatar
What are you having trouble with 4 stroke or 2 stroke
Old Jan 17, 2010 | 09:33 PM
odie22's Avatar
2 stroke its a sportsman 400
Old Jan 17, 2010 | 10:24 PM
NewportHillClimber's Avatar
possibly an air leak too. if the carb doesnt fix it check your crank seals
Old Jan 17, 2010 | 10:28 PM
odie22's Avatar
o boy are the crank seals hard to replaces?
Old Jan 17, 2010 | 11:13 PM
I am by no means an expert on this problem,just bought a 400 srambler and only a weeks worth of study on this engine, but I would look at the reed valves. You would do well by trying a search for your problem or being patient and someone more knowlegable than I will set you on the right path.
Old Jan 17, 2010 | 11:44 PM
odie22's Avatar
i have google everthing on the sportsman and all i get is info on the 08 ir newer sportsman
Old Jan 19, 2010 | 04:01 PM
tv4fish's Avatar
First thing I would do is try a new spark plug - then dis-assemble and clean the carb.
