In Every Polaris ATVer's Toolbox, there should be:
Old Feb 26, 2001 | 11:03 PM
  #21
scramdaddy400's Avatar
Countryguy to answer your question a "leatherman" is one of thoughs plier like looking things with all the accessories like knives, scissors, files, etc. that pop out from each side of the handle. It's like a swiss army knife except it looks like a pair of pliers.
2000 SCRAMBLER 400 2X4
SCRAMDADDY400
Old Feb 26, 2001 | 11:20 PM
  #22
SWAC1's Avatar
Don't recommend using it, but a can of fix-a-flat can save your bacon, unless you don't mind a nice walk back to wherever.
Old Feb 26, 2001 | 11:34 PM
  #23
Listen Schults, your the numnuts who owns 4 highly modified polaris ATV's. You have some nerve waltzing in here with that under your belt and bashing polaris.
Quote me if I'm wrong but does'nt owning over $23,000 grand worth polaris ATVs and $0 honda mean your a polaris fan or a just a blooming idiot.
LONG LIVE POLARIS!!!
SCRAMDADDY400
Old Feb 27, 2001 | 12:29 AM
  #24
rpaske's Avatar
who is #1 in sales ??? lol
Old Feb 27, 2001 | 12:53 AM
  #25
Traildog's Avatar
OK it's my turn. This is what is in my quad box when I go out trail riding.
A chain saw
50' 1/2" rope
8' length of chain + 10 12" nails. If there are no trees to winch to, lay the chain on the ground and every 6" or so push the nails through the chain into the ground. Then hook your winch the end of the chain and winch yourself out.
A Come-a-long
A ****** block
In my P toolbox is:
A tool kit with misc wrenches screw driver etc.
Spare spark plug
Small air compressor
Tire plug kit
Circuit diagram of my quad
Voltage tester
First aid kit
LP tire gauge
I also carry a GPS and topos
I think that's about it. If I think of something else I'll repost.
Old Feb 27, 2001 | 01:00 AM
  #26
NewDSLover's Avatar
No big deal if your close to home, but for them long, faraway ride. Like a snow mobil, an extra belt is a good thing to have in your bed of your truck. I've burned a belt and once back at the truck, in a few minute I'm back in business.
Old Feb 27, 2001 | 08:10 AM
  #27
OneDollar's Avatar
One small item you can add to your tool kit is a wire cutter. Especially if you ride anywhere near fences.
Get a wad of loose barbed wire wrapped around your rear axel and your free in minutes.
Without them your spending alot of time cursing and bandaging up your hands and arms while trying to figure out how to remove that beehive around your axel.
Old Feb 27, 2001 | 08:58 AM
  #28
DaBoss's Avatar
I read somewhere that you should bring a rachet type tiedown strap to use to fix a tire if it comes off the rim. I have one... but not real sure how I'd use it ??
Old Feb 27, 2001 | 09:47 AM
  #29
OneDollar's Avatar
You put it around the tire to help push the bead up to the rim to seat it while you pump air in.
I had the bead seperate from my rim last weekend (hit a root sticking out of the side of a hill)
Only one side was off the rim so me and two friends popped the bead pretty easily with a hand pump while we pushed up on the tire to seat it. One trick you to help seat it is to put liquid soap around the tire bead. (don't forget to clean the rim first!).
Old Feb 27, 2001 | 10:43 AM
  #30
MOUSIN's Avatar
....still taking notes.......
