Why a 35lb weight gain from a H.O to efi 500?
Old Feb 19, 2010 | 09:08 AM
TLC's Avatar
TLC
Question Why a 35lb weight gain from a H.O to efi 500?
2009 Polaris Sportsman® 500 EFI ATVs
I know the EFI has heavier 26" tires vs the H.Os 25" tires but that should be moe than canceled out by the H.O having steel rims vs the efi's lighter alloy rims. The 500 efi comes stock with a winch and the H.O does not maybe? Is the brain box that runs the EFI that heavy?
Old Feb 19, 2010 | 10:01 AM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
The winch is not light and the 26" tires are quite a bit heavier. The winch and mounting weigh at least 15 lbs.
Old Feb 19, 2010 | 04:16 PM
IQSLEDNECK's Avatar
the Aluminum rims are probbly just as heavy if not heavier than the steel wheels they are a lot thicker than the steel wheeles and the winch alone is probbly close to 30 LBS with the mounting kit and roller. According to DennisKirk.com the warn 2.5I winch is 27lbs shipping weight.
Also an average aluminum rim rolls in at just about 14lbs for a 12 inch wheel and a 12 inch steel rim rolls in at right about 14lbs
Old Feb 19, 2010 | 07:24 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i would say the winch has alot to do w/ it as well and the bigger tires are for sure more weight and beleave it or not the alum. rims are lighter then the steel ones even though it doesnt seem it.
shimanok2
Jan 29, 2016 07:37 PM
Robinhood
Dec 26, 2015 10:28 AM
Steeldon
Sep 9, 2015 09:38 AM
