Tire width question......
Old Mar 26, 2010 | 05:11 PM
oilcan1's Avatar
Default Tire width question......
Has anyone mounted a 9" wide tire on the front of their sportsman 500 ?
My stockers are 8" and bald and I found a good price on some 9" inchers,
but looks like the clearance is real close
Old Mar 26, 2010 | 05:49 PM
JCDEYO25's Avatar
9's are pushing it on stock rims...Gonna be real close if not rub tierod ends...jmo...
John
Old Mar 26, 2010 | 05:57 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you might be able to get away w/ it or you might be rubbing as well w/ out wheel spacers or aftermarket rims. imo
Old Mar 26, 2010 | 06:01 PM
Kerbbirds's Avatar
I have 9' mudlites on my 03 700, need 3/8 washers on the studs behind the wheels to clear, or flip the tie rod ends to the bottom side of struts and re-align,you still have plenty of wheel studs with the washers.
Old Mar 26, 2010 | 06:15 PM
It will likely rub. I ended up getting longer studs from SuperATV.com. Polaris Extended Wheel Studs #186 I got those pressed in and added 3/8" with a nut and a washer. (both hardened) It gives me at least 1/4" of clearance for the XTRs I put on.
Old Mar 26, 2010 | 07:28 PM
oilcan1's Avatar
Thanks all for the reply and suggestions.
I didnt even think about using some washers as spacers.
That may give me the clearance I need since there is only about 1/2" right now.
Moose - that link says they come as a set of 16,
do you want to sell the other 8 ? or are you using them ?
Old Mar 26, 2010 | 09:18 PM
700 sportsman's Avatar
there's four studs on each wheel 4X4 is 16 lol
Old Mar 26, 2010 | 11:47 PM
oilcan1's Avatar
Only the front 2 wheels have the clearance problem, smart guy.
lol
Old Mar 27, 2010 | 09:09 AM
I'd be more than happy to except I can't find them. I have no idea what I did with them. If they show up I'll let you know but they aren't where I would've left them.
Old Mar 27, 2010 | 09:19 AM
maverick11's Avatar
I just put 9'' Bighorns on my 2006 500 sportsman and i havent had any rubbing. I think it depends on the tire you get. The bighorns have very round profile so they just clear
