Need Some Help
Old Mar 29, 2010 | 10:49 AM
berringer's Avatar
Default Need Some Help
Hey guys im new to this forum and i thought i could maybe get some help. i have a 1999 polaris scrambler 400 2x4 and the throttle is broke when i touch the trottle just a little bit it takes off. alsowhen i let go of the throttle the bike shuts off. The Throtle is sotouchy now that i cant even ride it and i was wondering if it was the throttle spring in the carb or not if u guys can help me out that would be great thanks
Old Mar 29, 2010 | 07:10 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome to the forum. what or how is the throttle broken sounds like the cable is too tight and it's kicking in the etc which will activte the override so if the throttle sticks it will not rev more then say around 3,000 rpm's. the cable slack should be around 1/8"
Old Mar 30, 2010 | 02:02 PM
berringer's Avatar
Default Thanks
umm the thorttle is broke like the bike wont start unless u hold the throttle full and when u let go of the throttle the bike stops. also when u touch the throttle just a little bit it takes off full speed there is no pressure required to go full speed. but when it wasent broken it was normal and the throttle doesent get stuck.
Old Mar 30, 2010 | 04:41 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
maybe cable is broke or something inthe car has let go. time to take it apart for sure before you try to drive it.
