Predator carb on scrambler?
Old Mar 29, 2010 | 03:06 PM
SCR03's Avatar
Default Predator carb on scrambler?
hello, i think i read something somewhere about a carb from a predator being used on a scrambler 500 and was wondering if you guys had any information on doing that swap. as far as what year carb from the predator would work and jetting and if i would have to do any other adjustments. i have a 99 and 03 scrambler 500. thank you for any and all help in advance
Old Mar 29, 2010 | 10:01 PM
lslubecki's Avatar
I would like to put the Pred cylinder and head assem. on my scrammy. You can get a 600cc big bore for the pred but not the scrambler.
Old Mar 30, 2010 | 09:09 AM
MECHANIKE's Avatar
yeah personally i think the 500 is a beast of an engine,i would'nt do anything but throw a bigger carb,,,,,,,,i.m.o.
Old Mar 30, 2010 | 09:19 AM
SCR03's Avatar
thats what im trying to do but i can find predator carbs alot cheaper and they are a 42 mm compared to a 40mm. overall would the difference be noticable with a pipe and re jetted?
Old Mar 30, 2010 | 09:31 AM
TLC's Avatar
TLC
The 35hp Fuji 500 used in the Sportsman/Scrambler and 42hp Pred 500 motor are different. Ones a SOHC the other is a DOHC.
I don't thing moving from a 40 mm carb to a 42mm would make any noticeable gain.
These guys have a 600 and 628 big bore kit for the scrambler. http://www.fourstroketech.net/
Plenty of Scrambler stage kits here. http://www.aaenperformance.com/Power500.asp
Old Mar 30, 2010 | 11:34 AM
MECHANIKE's Avatar
yeah, i went from a 30mm to a 34mm on a 250 and Major League dif,,,,,,,,,i guess it depends on cost and tunability,the 34mm on the 250 was involved but after a few changes it was well worth it,,,,,,,,,
Old Mar 30, 2010 | 01:44 PM
MECHANIKE's Avatar
hey scr03 there are 2 predator carbs being bid on e-bay, want to go halfsy's?????? $25.00 right now,dislike the $25 shippping,,,,,,,,,,,,,,,,,,,
Old Mar 30, 2010 | 05:29 PM
three c's's Avatar
Default preadator carb
the scrambler carb is a cv type carb ,i read that it works off of air box vacuum. you cant mod the air box that much . I tried running mine without the lid , it ran like crap. The preadator carb is not a cv carb and not sensitive to air box vacuum instant throttle and air box can be modded anyway you want. Eventually going to put one on mine.
Old Sep 29, 2010 | 09:06 PM
McKay5858's Avatar
Pretty sure the predator carb is also a cv carb. Its a 42mm mikuni, same carb as on the outlaw 500's and the bomb's ds650's. As I still have the stock carb from my DS and i'm looking into getting a scrambler, has anyone had any success changing the carbs?
Cole Hadden
Jun 15, 2025 09:05 AM
1966F100
Jul 14, 2015 12:19 PM
maxjung
Jul 13, 2015 05:11 PM
1966F100
Jul 12, 2015 03:08 AM
steveo612
Jul 11, 2015 08:35 AM
