polaris 400 won't start
Old Apr 2, 2010 | 02:55 PM
schafjo's Avatar
Default polaris 400 won't start
hi - i am new to this forum and was hoping for some suggestions... i have a polaris 400 sportsman and it will not start. you turn the key and nothing is just won't fire. Checked the spark plug and there no spark coming to the plug.. checked the coil and their is no spark there either. we had to hook the battery up to charger because of sitting for months (have done this in the past no problems) but for some reason we heard a pop and the fan clicked on and the dash lights went out - cannot seem to locate the problem.. am new to working on atvs..
Old Apr 2, 2010 | 07:15 PM
4getful2's Avatar
i take it this is a 2 stroke?? what year??
you could try following the wires ,from the left handlbar ,to under the hood ,and disconnect the lil black wire. this negates the kill switch.
You may want to clean the connections on the battery and also check and clean your grounds,that may have popped your bulbs,check the rest while you're at it.
Old Apr 2, 2010 | 07:45 PM
Mongrol's Avatar
"Official Site Skeptic"
If its a 400HO (08 & newer) check the resetable circuit breakers.
Old Apr 4, 2010 | 04:01 PM
schafjo's Avatar
it is a 2005 4 stroke. thanks for the info - we did clean the battery connections prior to installing the new battery - i will try the cleaning the grounds - would this cause no spark to the coil...
Old Apr 4, 2010 | 05:11 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
how much ampage was the charger? try the pull cord to see if it still has no fire.
Old Apr 4, 2010 | 07:26 PM
schafjo's Avatar
Don't know ampage off hand - we did try to pull start and nothing. when you turn the key they lights come on but nothing it just won't turn over...
Old Apr 5, 2010 | 04:54 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it may have damaged the cdi or stator w/ getting no fire. imo
Old Apr 5, 2010 | 07:07 AM
schafjo's Avatar
that is what i am affraid of - is there anyway to test the stator and cdi to see which one is bad.
Old Apr 5, 2010 | 09:03 AM
Sawyer's Avatar
Just to make it clear does the starter spin the engine over when you push the button?
Old Apr 5, 2010 | 09:59 AM
schafjo's Avatar
yes it spins the engine just doesn't get enough juice or something to actually start.
