05 Sportsman overheating
Old Apr 3, 2010 | 08:07 PM
shane_12m's Avatar
Default 05 Sportsman overheating
I have an 05 Sportsman 800 EFI. It keeps overheating. I put a new sensor on it, and also hooked up the fan to direct power and it ran. What else should I be checkin?
Old Apr 3, 2010 | 08:23 PM
patrolman800's Avatar
Make sure the radiator is good an clean. Both sides dont just run a hose from one side you need to do both sides kind of a pain to get it good an clean but I would bet thats the problem.
Old Apr 3, 2010 | 09:36 PM
hunt1940's Avatar
patrolman i think is right..i had the same problem...if you do alot of mudding ofcourse.anyway i took my front box off and got down in there and it is fine now
Old Apr 4, 2010 | 05:47 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the 800's run hot as it is and you have even 25% of that radaitor plugged it could over heat. the boys are right on making sure that all the way through is clean. trust me if you have been mudding and did NOT clean it through and through back to front you won't clean it good and the heat just bakes on the mud. imo
Jenn1
Sep 8, 2015 09:16 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
cornermike
Jul 30, 2015 06:37 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
