Low Range
Old Apr 22, 2010 | 01:14 PM
maverick11's Avatar
Default Low Range
What is the top speed i should be riding in low range... the dealer told me around 15mph wouldnt hurt my belt but the manual says no more then 7 then i should be in high to maintain the belt...
Old Apr 22, 2010 | 01:31 PM
james feeney's Avatar
My dealer told me it would do 35mph in low!!!!!!!!
Can someone confirm the truth.
Cheers
James
Old Apr 22, 2010 | 02:19 PM
Pre XP Polaris is generally below 15 in low and high for over 15. The XP can do something like 30 mph in low.
Old Apr 22, 2010 | 03:00 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
I agree with moose
Old Apr 22, 2010 | 03:55 PM
I did test drive the XP and I think I'm getting mixed up with data the dealer was reeling off about it and not necessarily the HO.???
Old Apr 22, 2010 | 04:33 PM
switzomatic's Avatar
I cruise around in low around 15mph all day long and have never had any problems. The manual probably does say 7mph for the sp's but it won't hurt anything or shorten belt life. What kills belts is running in high at lower speeds. The others were correct on 35mph for the xp's.
Old Apr 22, 2010 | 06:26 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
any more then around 15 mph your winding the hell out of the engine. low range is for going real slow or working or hauling. it also helps cool the belt w/ more rmp's turning while going below 15 mph.
Old Apr 22, 2010 | 07:01 PM
09 popo HO's Avatar
Funny this thread popped up. I was just wondering this myself. I have always heard the 7mph - 15mph numbers in the past.
The other day I was playing around behind the house and brought the front end up a couple of times and wound her out after bringing the front end back down. I was coming close to 20MPH but only at 4500rpm give or take.
I figured at that speed I'd have her close to the limiter over the 6000rpm mark.
Any harm in 4500 - 5000 rpm in low. Will it hurt anything?
Am I right to assume that as long as my rev's are under the limiter I am not doing any damage?
Old Apr 22, 2010 | 07:46 PM
Think about it this way. If your crusing down the road in high range at 55 mph and the rpms are bumpin around 4500-5500 it would be no different than in low range going 15-20 and rpm's at 4500-5500. The clutch and belt are reacting the same way just the gearing is different. It's similar with a 4x4 truck, The tranny does'nt know the difference from high to low range just the gearing has changed.
Old Apr 23, 2010 | 05:08 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
no it won't hurt anything.
