03 Predator Spark then NOT
Old May 27, 2010 | 07:57 PM
Ding Nut's Avatar
Default 03 Predator Spark then NOT
I recently replaced the frame on my 03 predator....something having to do with a tree..long story...anyway..Prior to breaking down the bike the engine was running Perfect, put every thing on the new frame, and now when I crank it, I get a spark right away for a split second then NOTHING.
bad Ground??? I sanded down all the contacts to make sure they were tight and clean...still same issue
Bad Coil???? why would it go bad in a matter of a week while swapping out frames???
anything else I should check???
CDI????
Old May 27, 2010 | 09:24 PM
Ding Nut's Avatar
how often do Stators go bad???
Do you check the resistance across the three yellow wires??
I am working down the manuals check list......have power to CDI, 12 volts.
am lost at checking the Pulse (Tigger) Coil...says:
"Disconnect the pulse (trigger) coil connector from
the CDI module. Measure the resistance of the
trigger coil . Check reverse signal coil."
WHICH CONNECTOR???
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
steveo612
Jul 11, 2015 08:35 AM
