electric prob
I replaced stock headlights with aftermarket. Now quad will run short time and stall/shut down. after unplugging lights it runs fine .But with high beam (no low beam and 4x4 coil on it shuts down . what and where relay did I kill?
sounds like it's drawing way to much current. is it installed correctly w/ the right relay's?
Is it a newer Quad with the ECM (Sure Power Module)??
You did not list a year or model. ....Caper....... |
My 2006 Sp 450 would shut down when the lights were turned on (stock ones) this was the solid state circuit breakers shutting the Quad down for protection.....when I turned the light switch off and cycle the key back to off ....It would start again...............Until the light Switch was put on again...........Caper............
all i did was replace stock headlights with after market " driving lights" 55w walmart specials
all this sounds like my problem but where is the relay or breaker I tripped located so I can test it? I simply cut the stock headlight wires and added push connectors with new headlights. let the quad sit it resets its self and runs fine until I turn anything electric on. Then it shuts down.
Originally Posted by itstillruns
(Post 2952760)
..... ..... There is no relay or breakers if you have the Sure Power Module (black box),,(Silver is the new replacement one) the have solid state circuit breakers installed directly into the module.........The quad shut down on me right away when the lights were turned on.........If the Recall was not done =check into it. The reason the Quad turns off is for protection.........Caper.......... Nobody listed a year or model quad yet? Mine was on two Sp 450's ..2006 year. Caper.......... |
Originally Posted by caperinmuskoka
(Post 2952763)
Nobody listed a year or model quad yet? Mine was on two Sp 450's ..2006 year I tried these super duper brigh blue light bulbs in my sled last winter,they blew my Voltage rectifier and melted some wires. Big mistake. His sounds differen though,he stayed with the same 55W rating as stock and just did a straight foward wire connect. Should of worked simple. |
year
Oh I suppose this would help! its a 04 700 SP, early 04 carb model. still runnin! sorta
