Hand and Thumb Warmers
Old Oct 20, 2010 | 08:51 AM
TLC's Avatar
TLC
Every sled I own has hand and thumbwarmers ,make sure they have a low setting because on High thet can get to hot even through heavy gloves or mits.
I installed a Aftermarket set on a sled once,the instuctions where easy to follow,it was not a hard job at all.
Old Oct 20, 2010 | 09:22 AM
DODGE57HEMI's Avatar
Mopar Man!
Originally Posted by SomethingFishy
Hair spray works great for sliding them on, once they heat up the hair-spray acts like a glue and holds them in place.
Good Idea!
Old Oct 20, 2010 | 09:34 AM
scootergptx's Avatar
Supersock
Hired Gun!
Use that trick on the atvs and bikes.
Good idea to make sure you're wife isn't home when you do that.
ND_Rider's Avatar
Thanks for all the info guys!! I think I am going to go with the Symtec ones from Cabelas. Will let you guys now how they turn out.
Old Oct 20, 2010 | 12:55 PM
  #15
09 popo HO's Avatar
I installed a set of Kimpex hand and thumb warmers on mine. Like you I liked my current grips and didn't want to replace them. I got the ones that adhere under your grips.
Very happy with them. The also came with some nice switches. Round plastic rocker switches. Look very factory. More factory then factory switches in fact.
To get your old grips off without destroying them, use an air compressor with the blow gun attached. Place it unter the throttle end of the grip and pull outward as you give it air. She will slide right off.
The hairspray trick sounds like it would work well for putting them back on. I used waterless hand sanitizer since it's mostly alcohol and would evaporate. But the hairspray thing sounds like a winner.
Old Oct 20, 2010 | 03:34 PM
  #16
Just don't have any flame around when using hair spray. We use it in a spud gun we made and it is highly flamable.
Old Oct 20, 2010 | 06:18 PM
  #17
JCDEYO25's Avatar
If you get the Symtec's just remember to pay attention to the one step which says to put the grips in hot water for a bit prior to installing...This makes them more pliable and easier to slide on...Try not to stop as you are pushing them on as you might have a hard time getting going again...Hope this helps...
John
Hack714
Sep 26, 2015 08:11 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
01ssls1
3) General Discussions..
Sep 21, 2015 12:23 PM
Hack714
Sep 20, 2015 05:54 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
