1992 trailboss 350
Old Nov 26, 2010 | 04:01 PM
drmrjohn's Avatar
Default 1992 trailboss 350
Hi-Great board I hope to learn a lot here--i just bought this quad and have no idea how to get it into 4wd--can anyone tell me the proceedure for going to 4wd?
Also-it doesnt seem to charge the battery, but that could also be bad battery-is there a way to see that the charging system is working. I also don't know where to put antifreeze-lol i guess i should try to find a manual but i did try to google one but no luck-any suggestions? Thanks everyone!
Old Nov 26, 2010 | 07:26 PM
Kerbbirds's Avatar
Should be a button on the right handlebar for awd,Get a multi meter and put the red to red black to black on the battery, should read over 12 volts shut off, 12.5 to13.5 at idle, rev it up a little should show 13.5to14.5, dont turn lights on with dead battery it will blow the bulbs, could also be why you dont have awd,they need a battery to work correctlyCheck it out and let us know if its charging before you buy anything, we will help you diagnose.
Old Nov 27, 2010 | 04:13 PM
4getful2's Avatar
you'll most likely have to take the front cover ,where the oil tank and headlight are at, to get to the radiator cap. i believe the cooling system ,when bone dry ,holds 2 qts. there is a lil 10 mm. bolt on top of the head to bleed the air out of the system, remove when refilling and when coolant starts trickling out, replace bolt. do this with engine not running. start it up let it run long enough for the fan to cycle a couple times, top off radiator ,and fill resevoir and you should be good to go.
68_327_c20
Nov 25, 2023 12:26 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
Myronh
Sep 8, 2015 11:27 AM
Thwapp
Aug 25, 2015 09:54 AM
binky79
Jul 30, 2015 06:37 PM
