Winch running backwards
Old Dec 12, 2010 | 10:26 AM
james feeney's Avatar
Switching the cables will do the job. Spooling the cable all the way out and in again will bring the cable in over the drum rather than under which is how the winch was designed along with the position of the fairlead.
JF
Old Dec 12, 2010 | 06:00 PM
randyneff6971's Avatar
If you notice when the cable is retrieved the roller fair-lead is in line with the bottom of the winch drum and by switching the direction in witch the cable is retracted you will need to move the roller up about 2 inches so the cable is in line with the drum once again. Keep in mind the least the cable contacts anything will prolong the cable life. By fixing the problem properly instead of using a band-aid will cost less in the long run.
Old Dec 13, 2010 | 12:39 PM
JF
old quads
Aug 13, 2015 10:32 AM
RticKwad
12
Jul 19, 2015 12:22 AM
Madshad
ATC 3-Wheelers
Jun 28, 2015 02:43 PM
TLC
Jun 21, 2015 10:02 AM
Fullblast
May 26, 2015 12:38 AM
