scrammy 500 pipe and jetting help
Old Dec 25, 2010 | 11:30 PM
nation's Avatar
Default scrammy 500 pipe and jetting help
i got yet another srammy 500. im kind of wondering if i should do a full exhaust system/rejet or or a simple slip on and work on the clutching. i know the scrambler runs a little lean stock so would a 160 primary,fmf slipon and a good clutch set rock enough power?
is there maybe a budget full system ive missed?
Old Dec 27, 2010 | 10:59 AM
MECHANIKE's Avatar
i started out with a clutch spring,there are three descent ones epi sells depending how much higher you want.i went up 2g on the weights to grab the belt harder.changed secondary spring to the 2-2 position.there are carb mods done cheaply.found a descent muffler on ebay.
ReconBayou
Oct 31, 2022 05:37 PM
mrtidy
Feb 3, 2016 05:00 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Brandon400
Sep 5, 2015 08:44 PM
