05 atp no electrical power
yeah probably should have taken it to dealer but we probably have one of the rudest dealers in the world, and i called them and they pissed me off so i went to work ,now its all apart and im on a mission to fix it myself so here i am probably going to order an ecm............ listen to this ....my neighbor came up last week for a phone number while he was here he said you like that polaris? i told him i loved it, he said my buddies have them and they are junk ,wouldnt have one,better get a honda ......mine hasnt cranked since... it dont even have a pulse !now im on here lost with a pile of bolts hopeing yall can help
#15
sure sounds like the ecm to me.call a dealership and give them your vin number and they can tell you if your ecm was recalled. I have seen ecm cause all kinds of trouble like yours.most every thing on your machine is powered through the ecm.
#19
no ramman67 i havent ordered an ecm yet, i went to the dealership and they told me that it wasnt the ecm it was a wireing problem or the switch i told them i had already checked them,this knuckle head said i didnt know what i was doing and ''them e c m's dont go bad'' ,and i needed to bring it in and stay off the internet. i may have to junk it but it wont go to him ..so i thought i had better check everything before i order one ..this is a good clean machine and i have found nothing.. do you think the ecm is my problem
#20
sounds like your dealer is a real pain.They are telling you wrong about the ecms they do go bad.The worst thing is theres no way to test the ecm.Polaris has you check everything else and if everything else is ok then the will tell you to change the ecm.Back on the starter selenoid post that the battery cable hooks to theres also a small wire that has a fuseable link in it make sure its not burnt in half.If i remember right the wire is red and the link maybe gray.I work at a dealership and we have had some trouble with ecms. I will check the wiring diagram for your machine there may also be a breaker switch in your wiring harness there inside a black plastic pouch usually. hope this helps.
