fuel leak 2008 rzr
Old Sep 29, 2011 | 07:40 PM
rzr-zilla's Avatar
Default fuel leak 2008 rzr
Have a fuel leak at the fuelpump were it goes into the tank.
My polaris dealer sayes i must buy a new tank with the fuelpump already
inside. well over 500.00 bucks. Tryed new o-ring[polaris did not have one
so i got a match at hardware store] did not help. any ideas.
Old Sep 29, 2011 | 08:21 PM
Kerbbirds's Avatar
so its leaking from the o-ring that is under the pump?is the tank cracked, did you clean out the groove before you tried the new o-ring?try a little grease on the o-ring , I can give you a number for a new pump, its an -airtex E-8198 or carter 7000, these fit the 800 sportsman, should work on rzr, can get them at parts store for around $120
Old Sep 30, 2011 | 04:25 PM
rzr-zilla's Avatar
Default still trying to stop a leak
took fuelpump back out cheaked o ring. put back in with a little more tork
[38lbs] wating for battery to charge back up so i can try it.
Old Oct 2, 2011 | 09:45 PM
bentarrow's Avatar
First Things First!
My BIL took his RZR in before coming to Colorado in July and told the dealer to check it over and do anything necessary. We go for a ride in the mountains and the fuel tank is leaking. Now today he tells me he found a notice on the web of a recall for a fuel leak that the dealer never checked for and it was still under warranty in July. He is looking at the same $500 for a tank if the dealer does not fix it or the recall is only for warranty work. He was going to call Polaris tomorrow but I told him to start with the dealer and work his way up.
slowgsxr97
Mar 18, 2022 03:40 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
Unzzy66
Jul 11, 2015 10:01 PM
traumajunkie
Jul 5, 2015 03:03 PM
