Tb 250 mods??
Old Nov 21, 2011 | 11:52 AM
WhiteKnightInBlack's Avatar
Default Tb 250 mods??
hi all,, new member to the forum,,, own a 2002 trailblazer 250. fun ride for sure but looking to upgrade performance a little,, have read a lot here and am sold on ricks stage 1 kit,, lol as i am between jobs and ightin with unemplyment right now,, looking to do a few miner and cheaper upgradeshave already installed a ricks hot shot cd unit,, and while some claim it doesent help mutch as far as rpms,, it has definatly helped in the bottom and mid raing,, along with modifying air box,, now runs lean so,, going to up jet,, my question is,, the white polaris clutch spring has been mentioned a few times,, right now have the blue/green stock one,,i think?? blue with green markings, is the white spring stiffer?? alowing the engine to rev higher befoe engaging?? will this hurt top end? and should a tack be installed with this mod? any other thoughs, ideas,, sugestions?? when i get the money,, either job,,, unemp;yment or taxes am getting the stage 1 but for now that is on hold,, porting is an option at sometime also,, but will probably do that when time to rebuid motor along with millling head,, wiesco piston ect..
thank you in advance for any anwers,,, they are mutch apreciated
Old Nov 21, 2011 | 12:20 PM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
Pink (I think) primary may be another option for you as well.
Sounds like you've got everything covered or plan to cover it. Maybe tweaking the sprockets a bit when all the other stuff is added.
Old Nov 21, 2011 | 01:30 PM
thanks scooter, apreciate the welcome
what are the differences between the pink and the white springs??? should anything be dine with the springs in the driven clutch,, and what would you do with the sprockets??
Old Nov 21, 2011 | 01:42 PM
Supersock
Hired Gun!
Hopefully, OPT will be in and fill you in on the springs and the exact way they'll affect the performance. He's the guru here and any advice he gives has always been spot on.
The sprockets are more of a tinkering I did with my old trail boss. Did the RCR stage 1 and it really gave it a lot of low end grunt. Problem was a lot of riding we did back then was in sandy trail conditions. So a few times the wheel spin dug more than it pulled out. Changed the front sprocket and it leveled it out, to me anyway. You may want to look at the current chain and sprockets and see how they've worn. When you do the work later, you could get a new set up fairly cheap off ebay.
Old Nov 21, 2011 | 01:50 PM
thanks,,,, and sounds good,,, do a lot sand trail,, and dune riding here,,, high dessert.. most of the riding is in the middrainge i gues you woul say,, but some of the hills,, to get up its flat out lol the cd i unit heklped with the air box cover removed,,, but would cut out on long pulls at FT so,, running lean. this TB has had reletively light use on it,, till now hehehehe so sprockets show very little to no wear on them at this point,,, part of the reason not doing more major mods yet,,, still like new ,, and money of course lol
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
JakeXBL
Sep 5, 2015 01:08 PM
