DG Pipes?
Old Mar 16, 2001 | 03:45 PM
shakeyjake69's Avatar
Does any one know how good DG's pipes work on scramblers any help would be great thanks.
Old Mar 16, 2001 | 05:43 PM
A400L's Avatar
DG is JUNK, RCR and HPD is the only way to go.
Old Mar 16, 2001 | 06:16 PM
yamaracer5's Avatar
A400L is right.I have a DG pipe on my Scrambler 5004x4 and all they are good for is making a LOT of noise.Mine doesn't even put out any more power than stock.If i had to do it all over again i would go with a HPD.Hope this helps any.
Old Mar 16, 2001 | 07:58 PM
sparkster's Avatar
I disagree and agree with the two others that posted. DG isn't junk, it deffinatley gave my scrambler 400 some better pickup, but I do agree with them when they say the other brands are better. If I had to choose, or do it all over again I would probably go with hpd. It's an alright pipe but not a great one. As for noise, it's the same as the others I have heard, mufflers that is.
Old Mar 17, 2001 | 03:14 AM
wrench101's Avatar
Any aftermarket pipe is better than that 30+lbs system you have on there now.
DG has made some huge changes to there pipes in the last year and started putting a lot of research into the performance of each system.
But just because of there bad reputation building up a new one is going to take a while.
For the low cost of the dg pipes you get a fair bit for your $$$ maybe still not as good as some of the more exspencive pipes.
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greg86hd
Sep 16, 2015 12:32 AM
bvolks
Sep 13, 2015 12:57 PM
