Fuel Problem?
Old Aug 4, 2012 | 05:50 PM
TxMagnum's Avatar
Default Fuel Problem?
I'm sure this is pretty common but I am having a hard time figuring it out....
It will start when I spray starter fluid in the carb but dies immediately. Once it ran for about 20-30 seconds when I had the choke all the way closed (or open, whichever is with the lever out of its normal operating position)
2000 polaris magnum 500
New fuel pump
new petcock
new spark plug
new gas
clean filter
fuel and vacuum lines inspected, no apparent leaks
clean fuel filter
choke cable recently replaced, I believe it to be adjusted correctly
Thanks for any advice....
Old Aug 4, 2012 | 11:59 PM
Seems like you've listed everything except the carb needle and seat. If you haven't taken the carb apart and cleaned the jets and replaced the needle and seat,could be the problem. Plus check that the spring under the top cap is holding the slide needle properly and hasn't jumped around. OPT
micheleLeigh
Jul 12, 2015 02:50 AM
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Mikea1978
Jul 4, 2015 12:37 PM
