Stator Watt's....
Old Feb 23, 2013 | 04:51 AM
Adrian Turner's Avatar
Default Stator Watt's....
Can somebody tell what size (watts) my stator is on my 2004 sportsman 700 twin please. I would like to run some extra spot lights and a winch. I'm entered into an event that has a long night run with winching so i'm worried i will run my battery (New Odyssey PC545) flat if i fit extra lights and winch at the same time!
Is there an upgrade kit or abigger Stator i could fit???
Old Feb 23, 2013 | 09:14 AM
Manual shows 500 watts @ 6000 rpms on the Kokusan stator.But that's at maximum output. 50 watt pod light, two 27 watt grill lights stock. If you have a stator question,here's one place you can can contact. http://www.rickystator.com/catalog/polaris-c-24_38.html
Unless you try to run everything at the same time(which most people wouldn't do) you shouldn't have a problem running an Odyssey down as long as the charging system is good and charging 14 volts back to the battery.If you don't want to use HID lighting an Led system can draw less wattage.
Amazon Amazon
Old Feb 25, 2013 | 03:58 PM
Thanks OPT Good to hear its a 500 Watt and not a 250 watt like i was thinking!
Old Feb 26, 2013 | 01:21 PM
james feeney's Avatar
Adrian,
I tried rickystator last year but they couldn't help me.
These guys love pictures and an update of what you're doing.
JF
Old Feb 27, 2013 | 05:36 AM
Noted buddy.....
ultangler
Nov 30, 2024 01:35 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
kbazzy
Sep 26, 2015 11:26 AM
johnny1982
Sep 13, 2015 07:41 PM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
