Polaris Sportsman 400
Old Mar 11, 2013 | 11:36 AM
Cummins Driver's Avatar
Default Polaris Sportsman 400
Hey guys, thinking about going to look at a 2001 sportsman 400 today. Guy said it started and ran a little then died. Battery is dead and gauge cluster doesent work. Not sure how related those two things are. I can get it for what I think is a fair price given the engine is mechanically sound and only needs fresh gas or a carb cleaning. Don't know how many miles are on it, but it has original tires that are a little worn so im thinking it shouldn't have too many miles on it.
Anything particular to look out for on these if I go look at it? I know these are basically identical to a sportsman 500 aside from engine displacement(455cc) which is a pretty solid machine. Never had a Polaris but wouldn't mind to try one out.
Old Mar 11, 2013 | 02:45 PM
Apparently after some research the 2001 sportsman is 425cc. Dont know when they went to the 455cc engine in the 400's.
Old Mar 11, 2013 | 04:18 PM
See if this discussion helps any or just confuses you more. http://forums.atvconnection.com/pola...ris-400-a.html
Old Mar 11, 2013 | 06:54 PM
It helps, thanks. I watched ATVTV.COM's youtube video review of the 2003 Sportsman 400 which I think is the same machine as the 01. They praised how smooth the engine was, but over all they dont seem to like polaris real well so there wasnt a lot of good said. I didnt get a chance to go tonight. It was raining cats and dogs, so I came home and worked on my Grizzly (got the crank out!), and Im going to be busy tomorrow night as well, but if he still has it Wednesday I may go look at it.
Old Mar 11, 2013 | 10:23 PM
How is the 425cc engine in the 400 OPT? Is it based on the 500 engine?
Old Mar 11, 2013 | 10:37 PM
user493's Avatar
Moto Psycho
The 425 and 455 are both based on the 500.
Old Mar 12, 2013 | 08:10 AM
TLC's Avatar
TLC
There all the same Fugi built motor just different bore and stroke for the 425. The 455 shares the same stroke as the 500.
The 500 just had a higher duration cam and a larger 40mm carb to make it a H.O in 2001.
As far as I know the the only difference with the 425 vs the 500 chassi wise in 2001 was it had no EBS engine braking .
If it has stock tires it should have goodyear P Trackers.
Old Mar 12, 2013 | 10:55 PM
Thanks guys. After some research looks like the gauge pod/ speedo go bad pretty commonly which also causes 4wd not to work. The new speedo isn't cheap and even though I read you can bypass the speedo I'd have to think on it some.
Can a bad speedo keep it from running?
Old Mar 13, 2013 | 07:24 AM
Yes the reverse limiter is built into the speedo on the 2001 400 also. Not common for it to screw up and limit in forward,but has happened. We didn't sell a lot of 400s for the reason that most people just jumped up to the 500. Nothing wrong with them,especially if you can get one at a good price.
Old Mar 13, 2013 | 08:08 AM
He said $1000 was his bottom dollar. I figure it's a $2000 machine when it's running right. It looks nice for the most part. Front rack has a small piece broken off, front tires are worn. Other than that and it's current not running issues it looks real clean. I figured that the 500s were a lot more popular but since the 400 is the same machine minus some horsepower, then it is a tried and true design. Never had an IRS ATV but I know Polaris has one of the most comfortable suspensions and seats and figure it would be real comfortable with my wife and I on it. I'm thinking on it. I'll be going tonight if I do decide to look at it. Thanks for the info guys.
