'09 850xp not starting
Old Mar 26, 2013 | 08:49 AM
wlvrn's Avatar
Default '09 850xp not starting
went to go ride around the property last week and my 850 would not start it just clicked at me. i charged the battery and still nothing. i took the starter off and it was very dirty so i cleaned it inside and out. put it all back together and now it turns over but will not start. it fires and acts like its going to start but it dont. i did get it to start one time but it sounded like a cold diesel engine right at start up and as soon as i took my thumb off the throttle it died. any thoughts what could be causing this??
Old Mar 26, 2013 | 09:54 AM
Make sure you don't have too much slack at the thumb throttle.Pop the throttle cap and the etc contacts should have 2mm clearance between them.Just adjust the throttle cable if needed. If thumb throttle is is too loose it can die if the contacts touch. Check also when you turn the key on you can hear the fuel pump prime up.Plus you can remove the cap from the fuel rail shrader valve and press it to see if fuel flows out and is getting to the injectors.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Mar 26, 2013 | 12:11 PM
wlvrn's Avatar
ill check it. thanks man. the pump is priming like its supposed to. i didnt think to check the shrader valve as this is the first issue i have had with the 850 and all i did was take off the throttle body and starter
Old Mar 26, 2013 | 03:13 PM
That could have something to do with it? Are you sure the o-rings(item#7) are back in place or did you install new ones?? Open the shrader valve and see if it helps after you prime the pump up again. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Mar 26, 2013 | 07:02 PM
wlvrn's Avatar
The 4 orings looked good and i reinstalled it to make sure it wasnt a pinched oring. There is gas at the shrader valve. Checked the hoses, harness and the orings again still wont start.
Old Mar 26, 2013 | 07:15 PM
One other thing is check the small wiring coming from the tps and other sensors. Same thin wiring and connectors as previous models of the 500,700,800 efi machines.All it takes is a small sliver of a bare wire grounding out or an internal wire breakage(soft spot in wiring) to stop one from running.
Old Mar 28, 2013 | 08:59 AM
wlvrn's Avatar
ill look real close this weekend to see if there is any thing there. i looked it over real fast when i put it all back together and i didnt see any thing but ill take a closer look. any thing else i should look for?
Old Mar 30, 2013 | 07:51 PM
wlvrn's Avatar
Found the bare wire. Cleaned it up and sealed it. Still doesnt start. It acks like its not getting air or keeping a spark. I do have spark tho
Old Mar 30, 2013 | 09:38 PM
Don't over look any soft feeling sensor wires that could be broken internally causing intermittent spark.Sometimes it's a tedious process especially if no codes are thrown on the speedo.
Old Apr 1, 2013 | 08:11 AM
wlvrn's Avatar
ok ill check that. thank you
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
