Clutch issues
Old Apr 7, 2013 | 06:02 PM
jampg's Avatar
Default Clutch issues
I'm reinstalling the engine after a top end rebuild on my 03 Predator 500. Prior to rebuild the clutch worked fine. I did pull the clutch off to make sure I had the lower timing mark in alignment. Everything was marked and reassembled as it was. Now the clutch lever does not return. With the cable off the engine the lever does move freely but not a whole lot of tension. The engine is still dry and has not been started yet. Should the clutch have more tension now or am I missing something?
Thanks.
Old Apr 7, 2013 | 06:23 PM
Should be about 3/16 to 1/4" free play at the lever,but you should have tension when you pull and should release back. Retrace your steps,check the case lever spring along with the internal clutch parts,clutch springs,rod and pusher. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
ghost civic
Jan 15, 2020 07:43 AM
Mikesohio
Jul 26, 2015 10:51 AM
ghost civic
Jul 15, 2015 10:48 PM
Unzzy66
Jul 11, 2015 10:01 PM
200es
Jul 10, 2015 09:09 AM
