04 predator
Old Apr 14, 2013 | 08:36 PM
04predator007's Avatar
Default 04 predator
hey new to the forum was out on my predator lost power to everything got it back to my house tor it apart found that the 20 amp relay was just hanging there got it hooked back up now when i turn the key it starts on it's own with out tuching the start button cant figure it out it's drving me nuts
Old Apr 14, 2013 | 10:27 PM
Sounds like a short in the left control start switch sending power to the starter solenoid.You might want to take the control apart and check the soldered wires in case they're touching,plus pull the connectors at the switch and trace the wiring down into the harness for any shorts also. I've had solenoids short out also,but usually they will turn the starter over without having the key on and you have to disconnect the battery to stop it. Plus ignition switches themselves can short out causing problems.
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Elkaholic
Sep 6, 2015 02:44 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
