Scrambler starting problem, Starter or Battery?
Old Jun 14, 2013 | 02:52 PM
CGirl10's Avatar
Default Scrambler starting problem, Starter or Battery?
Before I go out and buy a new battery I figured I would ask here...
Lately my 08 Scrambler 500 has been having issues starting with the automatic start. I turn the key and it sounds as if its just cranking over and over, but no start. It will start on the first or second pull with the pull start, then after running for awhile will start with the automatic start.
Corrosion has been cleaned off the cables.
Does this sound like a problem with the starter or battery?
Thanks
Old Jun 14, 2013 | 03:02 PM
I'd still have the battery load tested to eliminate it as a problem,but check this members post out. Sounds like you have a common problem that happens on the 500 Sportsman.You can pull start,but not electric start. http://forums.atvconnection.com/pola...ml#post3155476
Old Jun 15, 2013 | 07:59 PM
CGirl10's Avatar
Good news, new battery and fires right up
Old Jun 16, 2013 | 07:45 AM
Keep the new battery on a cheap maintainer and it will last for years..
tiresharkdbb
Sep 3, 2017 02:06 AM
BigRedGrizzly
Jun 7, 2015 11:06 AM
garyt1975
Jun 5, 2015 08:53 AM
vipers
1) Engine problems..
May 31, 2015 09:12 AM
1000gade
May 27, 2015 12:37 PM
