07 sportsman not charging
Old Jun 21, 2013 | 07:50 AM
Fubar008's Avatar
Thanks for all your help. Stator seems to be working fine. I checked every connection again so I guess it's time to bite the bullet and by a new pdm. Can I just hook the new one up or does it need to be calibrated By a dealer? Thanks again
Old Jun 21, 2013 | 07:59 AM
No it doesn't have to be programmed.
Old Jul 23, 2013 | 07:29 PM
Fubar008's Avatar
well it took awhile but i finally got a new pdm. installed it tonight and nothing changed I'm ready to burn this thing. what did i miss?? i researched this to death and was almost positive the pdm was the problem. if the battery was junk it would still show 14 volts running right?
Old Jul 24, 2013 | 03:14 AM
Not always,plus if you haven't had the battery load tested during this process you could have a dead cell. You said the stator checked out,you have a new pdm,so that either leaves a bad battery or a wiring/connection problem as the most likely suspect.
Old Jul 25, 2013 | 02:38 PM
  #15
Fubar008's Avatar
i went to polaris and had the battery tested, it came back bad so i bought a new one. installed it and still wont charge.
Old Jul 25, 2013 | 04:44 PM
  #16
Recheck the stator resistance and vac range I gave you earlier. This is from the manual. If stator resistance and vac is in range and you're sure it's not a connection /wiring problem,then it's entirely possible to have a "new" faulty pdm module. This you might talk to with the dealer or where ever you got the pdm from,if it helps any at all,as many will not accept electrical part returns for cars,cycles,atvs,etc. I've had the same issue on batteries bad straight out the box along with faulty"new" ecm modules on the 2004-2006 carb models on ecm recalls.At times like this is when it does pay to have a dealer work on machines as you wouldn't have to be going through what you are now..
Old Jul 25, 2013 | 06:00 PM
  #17
Fubar008's Avatar
Thanks for all your help. I'm going to recheck everything and go from there. worst comes to worst ill take it to a dealer
bzdok1234
30
Feb 23, 2016 01:55 PM
cody500ho
14
Aug 14, 2015 05:03 PM
Ronbo6270
Aug 6, 2015 11:54 PM
Karas3434
Aug 3, 2015 09:17 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
