04 Predator 500 Question
Old Feb 8, 2014 | 09:00 AM
Gavman9966's Avatar
Default 04 Predator 500 Question
What hubs will fit the polaris predator 500? I don't want a 100$ hub and i found a Outlaw MRX Hub will that work?
Old Feb 8, 2014 | 10:28 AM
Looked at some of the Scrambler part#'s but don't where they would interchange or not. Diameter and spline count are the main thing,but Polaris is fairly universal in this.Some one on another forum said they use Predator hubs on their Scrambler 500,but who knows unless you you try one. Think the Outlaw used Dura Blue axles if I remember correctly.
Old Feb 8, 2014 | 12:32 PM
Gavman9966's Avatar
someone said the Mxr hub will fit.
Old Feb 8, 2014 | 12:42 PM
Gavman9966's Avatar
http://www.ebay.com/itm/like/400654169080?lpid=82
Old Feb 8, 2014 | 03:03 PM
Gavman9966's Avatar
bump.
Old Feb 9, 2014 | 09:24 AM
Gavman9966's Avatar
would the outlaw MXR HUBS FIT?
Old Feb 9, 2014 | 10:29 AM
Maybe this will help from a members earlier post. Same as the Outlaw as you may encounter some the same problems in trying to change hubs.
"Here is what i know about the 03 predator hub swap . the predator hubs have the same shaft diameter and spline count as my stock magnum 500 hubs . where they differ is the predator hubs are just a little longer than the stock hubs and won't allow the castle nut to thread onto the axle far enough to let the cotter pin fit through the hole in the axle . if you know someone with a lathe or mill to counterbore the outside face of the hubs then this problem is an easy fix . the next problem you are likely to encounter is proper backspacing . apparently the hub to hub measurement on straight axle machines is less than the hub to hub measurement on the irs machines . i got around this problem by using factory polaris 12'' steel rear wheels with a 5+2 backspacing and flipping them around so that the tire valve is now on the inside and the wheel now has a 2+5 backspacing . this won't work with aluminum wheels and aftermarket wheels with the proper backspacing are not cheap or easy to find . i hope some of this information is helpful and your project goes well."
wendal
Oct 31, 2017 03:31 AM
bigred20653
Oct 2, 2015 10:05 AM
mark23
Oct 1, 2015 09:57 AM
greg86hd
Sep 16, 2015 12:32 AM
Elkaholic
Sep 6, 2015 02:44 PM
