Ranger Rims on a Sportsman
Old Apr 23, 2014 | 03:10 PM
pagraham's Avatar
Default Ranger Rims on a Sportsman
I have my eye on some stock rims that came off a 03 or earlier Ranger and just wondered if they will work out on my 04 sportsman, the diamenter and bolt pattern are good, I was concerned about the offset.
Any advice would be appreciated.
Thanks
Paul
Old Apr 24, 2014 | 09:06 AM
TLC's Avatar
TLC
Just measure the off set with a tape and see if there the same.
Should work according to this chart they both have a 4+3 offset. ATV Tire and Wheel Application Chart : ATV Tires Free Shipping : ATV Wheels : Mud-Throwers.com
Old Apr 25, 2014 | 10:58 PM
pagraham's Avatar
I bought the Ranger rims, it turns out they had the same offset as my original steel rims.
Now I'm just wondering if the standard studs are long enough.
The rims are thicker but came with tapered lug nuts, probably get approx. 1/2" of the stud threaded into the lug nut.
I wonder is this typical, I'm sure a lot of folks have upgraded from steel to aluminum rims.
Would like to know what others find acceptable on the stud length.
Thanks
Paul
Old Apr 26, 2014 | 10:01 AM
Extended studs are available at a lot of places if needed.Polaris Extended Wheel Studs [WSP9] - $19.95 : ATVonics, Best in ATV and UTV Accessories and After Market Products
Old Apr 26, 2014 | 02:28 PM
pagraham's Avatar
Thanks OPT, I'll order a set.
Old May 1, 2014 | 09:50 PM
TaterTots's Avatar
I thought the same thing when I put my aluminum rims on. The original studs turned out to be plenty long with the tapered lugs, though. 2000 Sportsman with 14" rims and 26" tires.
southbayman
Jul 24, 2015 09:30 AM
coldnorthpol
Jul 14, 2015 11:22 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
