water in oil
Old Sep 16, 2014 | 06:34 PM
trouttracker's Avatar
Default water in oil
Looks like I have some water in my oil on my 425 magnum it has not been sunk or in water at all. What can be causeing this and how would you test or check to rule out each one.
Old Sep 16, 2014 | 06:48 PM
SWFLMUD's Avatar
is it air cooled or radiator??
dip-stick tube sealed?
I had a constant rubbing on my lower portion of dipstick tubing which eventually wore thru and mud got in and destroyed the shaft bearings. very expensive lesson learned on motor mount replacements which would have prevented this.
Old Sep 16, 2014 | 07:02 PM
water cooled
Old Sep 16, 2014 | 10:22 PM
sandmanrrr's Avatar
Water pump bearing?
Old Sep 17, 2014 | 02:28 AM
You can have a whitish residue film show up on the dipstick or top part of the oil tank from moisture accumulation from the crank case vent and oil tank vent.This can happen over time.If the dipstick is really milky best to just pressurize the radiator to see if it holds 10psi with out any drop.If the pressure drops,could be seeping coolant from the head gasket or base gasket mixing in with the oil.
Customer Service #1
May 15, 2020 08:46 AM
Alex G.
Sep 11, 2017 11:38 PM
panicmanic
Sep 28, 2015 12:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
