Polaris Magnum 425 4x4 issues
Doesn't happen often,but check fuel valve in the on position and also reserve position. Fuel valves can stop up along with filters. Dirt Cheap Yamaha & Polaris OEM Parts & Accessories – Cycle Parts Warehouse If fuel valve is okay,then yes you can turn the fuel valve off,pull the intake line from the tank to the pump(top line) add a section of hose if necessary to reach the carb. Clamp off the line until it's hooked to the carb or you'll have a mess.
Well i went out and double checked.... I am in fact getting fuel from the fuel filter.... so i guess the next thing for me to do when i get some spare time is to check the cams for wear.... uhhgg.... im starting to think i paid too much for this thing now lol
You never know on a used machine. Aftermarket cam and rocker arm are available on ebay if needed. http://www.ebay.com/itm/NEW-ROCKER-ARM-CAMSHAFT-POLARIS-MAGNUM-425-2x4-4x4-6x6-1995-1996-1997-1998-CAM-/360496402521?pt=Motors_ATV_Parts_Accessories&hash=item53ef429059&vxp=mtr
Big600twin
14
Jun 16, 2015 09:30 AM
mattlvsbball
Apr 24, 2000 06:54 PM
