2001 Polaris 400 scrambler
I have a 400 Polaris 400 scrambler that will not charge! I have tried a used regulator and still no change. If I rev it up the volts drop then go back up and settle back to normal im not getting 13 volts. I have a question it has an exciter coil is this so the atv just runs and not charge or is this part of the charging system? Or is the stator itself bad? Anyone know how to test this system? Or what my problem is it starts and runs fine just know theres different charging systems on these 400s.
The exciter(trigger coil) is for the ignition system.The main stator is for charging and lighting. You can test the stators yellow and yellow red to each other,should not zero out,plus neither one should short(zero out) to ground. If either wire does,then the main stator is faulty.Problem is that you have to get the stator and trigger coil assy. If you're sure that it's not a regulator problem,these stators are becoming kinda hard to find if you search for only a 2001 model 400,but the part number does share different year models that can help.The trigger coil can be found easier on ebay as many fit all the 250,300,350 and 400 models.
Usage : 3084785 This is the latest part number for the stator assy.
Year Product Model Assembly
2003 ATV TRAIL BLAZER 400 MAGNETO - A03BA38CA
2002 ATV SCRAMBLER 400 2X4 MAGNETO - A02BA38CA
2002 ATV SCRAMBLER 400 4X4 MAGNETO - A02BG38CA
2001 ATV SCRAMBLER 400 2X4 MAGNETO - A01BA38CA
2000 ATV SCRAMBLER 2X4 MAGNETO - A00BA38CA
2000 ATV SCRAMBLER 400 MAGNETO - A00BG38CA
1999 ATV SPORT 400 MAGNETO - A99BA38CA
1999 ATV SCRAMBLER 400 MAGNETO - A99BG38CA
1999 ATV SCRAMBLER 400 MAGNETO - A99BG38CB
1998 ATV SCRAMBLER 400 MAGNETO - W98BC38C
1998 ATV SPORT 400L MAGNETO Sport 400L W98BA38C
1997 ATV TRAIL BLAZER MAGNETO (SPORT) Sport 400L W97BA38C and Trail Blazer W97BA25C
1997 ATV SPORT 400L MAGNETO (SPORT) Sport 400L W97BA38C and Trail Blazer W97BA25C
1997 ATV SCRAMBER 400L MAGNETO Scrambler 400L W97BC38C
1996 ATV TRAIL BLAZER ES MAGNETO (SPORT) - W968540
1996 ATV SPORT 400L MAGNETO (SPORT) - W968540
1996 ATV SCRAMBLER MAGNETO ASSEMBLY Scrambler W967840
1995 ATV SCRAMBLER 4X4 MAGNETO ASSEMBLY Scrambler W957840
1994 ATV SPORT 400L MAGNETO ASSEMBLY Sport 400L W948540
Some used ones on ebay,plus even Caltric may have them,but not showing up. Looks like your pic shows to be Caltric stator for your model. Most online places are NLA.Item#7.http://www.cheapcycleparts.com/oempa...ea4054/magneto
Should be resistance between the yellow and yellow/red(yellow with a red stripe,NOT the solid red wire.) 2001,2002 and the the last 400 made,the 2003 Sport 400 used your type ignition as the 2 stroke 400 was be phased out of production. The Explorer 400 used the newer type magneto with the external pick up coil,but the stator plate is different along with the flywheel. Unless some aftermarket companies have changed to the later type ignition,you'll probably have to stay with your system.
