Hub fluid and Grease?
Little confused about greasing wheel bearings and using hub fluid.Wouldn't the grease contaminate the hub fluid? Although that seems to be the recommended procedure
Originally Posted by ranvette
(Post 3287361)
Thanks Polaris Tech !!!!!!!!!!! That is the way i did the bearings light on the grease !
Than i lifted it so all 4 wheels were off the ground and did a complete AWD function test.In forward and reverse using the over ride button.The system seemed to work perfectly. It goes out for its test ride in the woods tomorrow !!!!!!!!!! |
