1996 Polaris Xpress 400
Could be worn out springs or may take some rtv to seal up around the belled joints.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse Or even the exhaust manifold can be leaking causing excess noise.Item #11 Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
Sorry! Ithought the reply had posted....
Exhaust manifold was LOOSE, the nuts had backed off. Tightened 'em up, Voila! Sounds like a 4-stroke. I hear a high pitched whining sound when i accelerate fast, but i also hear it on my cousin's '04 Polaris Ranger. Coincidence? or common sound/problem? Thanks in advance.
#17
Still several places to get this Gen4 winch mount for the 2 wheel drive Express. Shares the same basic style as the Explorer. Some are on ebay.1996 1997 Polaris Xpress 400 Warn Winch Mount 34901 | eBay Plus you might contact these people.Polaris Generation 4 Winch Mount - Winch Mounts - POLARIS - SPORTSMAN - Sportsman 500 - 1996-2003 Sportsman 500 - Polaris Generation 4 Standard Winch Mount (Stock) - KFI ATV Winch, Mounts and Accessories Most people will recommend a Warn 2500 lb winch,but if it's beyond what you want to spend,plenty on ebay again.Reliability might be a factor if you go with a cheap one. 2500 atv winch | eBay
#19
Automatic Gear case Lubricant. Or any suitable equivalent synthetic gear case oil.http://www.ebay.com/itm/Pure-Polaris-AGL-Synthetic-Gearcase-Lube-Transmission-Fluid-1-Quart/231331703434?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D32238%26meid%3D210bc07bf69449fbb609031d2647b085%26pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D201335948738&rt=nc AMSOIL Synthetic ATV/UTV Transmission & Differential Fluid OR any other oil that's ok for chain driven gear cases. Don't use 75/90,80/90,etc as it's too thick to splash around to lube the bearings and gears.
