old polaris tech |
07-01-2015 03:59 PM |
I guess I did it the hard way or cheated as air tools make this a fairly easy job.I removed the tire,tie rod,then I clamped the cartridge shaft with a shop towel and vice grips to hold it steady,loosened the top strut nut with an air ratchet or wrench if I couldn't get the ratchet on it.Lowered the strut assy down slowly,impacted the cartridge nut off and removed the spring retainer plate,removed the old spring. Some people used straps,spring compressors,etc,but I just used the vice grips again after the new spring was on,ramped the vice grips up a rung or so just enough to compress the spring,got the retainer cap and nut started. I impacted the nut tight,replace the lower plastic pivot,shoved the strut up in place,replaced the top pivot,rubber and steel washer and nut and I was through.Hard part is to make sure you don't pull the cv joint apart at the strut when working the spring off and on! Air tools make work a lot easier if you have to do this day in day out. ALL depends on how heavy gauge the springs are also. Some springs I couldn't do this way and had small spring compressors to help pull them down far enough to get the spring retainer plate and nut back on. Some have used ratchet straps,etc.
__________________
