2000 sportsman 500 stator help please
Im in the process of restoring my dad's 2000 sportsman that he has owned since new. My problem is that he needs a stator. But it seems they changed the stator design in mid 2000 with his having a build date of 3/09/00. All of the stators that ive seen for his model # have 1-2plug and 1-3plug (with a extra green wire)connectors that go to the cdi, but his cdi takes only 2-2 plug connectors. And the later 2000 stator has the right plugs as his, but the stator itself will not fit onto the case......the dealer hasnt been much help and neither had the tech hotline. So im here asking for help and any is much appreciated! Thanks
Ricks has both styles,but aren't the cheapest around,but I'd trust them more than the rest of the online places.
2000 Polaris ATV Sportsman 500 4x4All Terrain Vehicle New OEM Style Polaris Stator Aftermarket Parts 2000 Polaris ATV Sportsman 500 4x4All Terrain Vehicle New OEM Style Polaris Stator Aftermarket Parts
I have actually already purchased both stators that are listed. The older style bolted up and will run but only at idle, but the plugs dont match up going to the cdi. This is my problem. I tried the newer style and it in fact has the same style plugs going to the cdi, but will not bolt up to the case. On the pre ho stator, i had to cut the 3 headed plug that has to red wires and a green wire and run red wires to the cdi. They matched up. But my problem is the green wire. If you start it up it will idle all day, but as soon as you giving it gas it stumbles and misses. But if you ground out the green wire from stator it will run great, but it will NOT start with green grounded out. Thanks for your quick responce.
2000 Polaris ATV Sportsman 500 4x4All Terrain VehicleSpam word New OEM Style Polaris Stator Aftermarket Parts 2000 Polaris ATV Sportsman 500 4x4All Terrain VehicleSpam word New OEM Style Polaris Stator Aftermarket Parts
Last edited by old polaris tech; Feb 25, 2016 at 06:57 PM. Reason: Engine serial #
it kinda seems as if it has the newer style cdi box, but with the old style stator. But i know for a fact that all the electrical items are all orginally, except for starter. I wonder if they made a different stator for a few months other than the 2 that are listed. Because this one does not have a connection for that green wire. Again thanks for your help!
Not that I'm aware of as this is a direct copy of Polaris Parts catalog. Looked through it (all 10 models of the 500 including the RSE)and all models show the same two stators depending on build date.
wow im at a loss then. I dont know what to do with the green wire. Theres no where to plug it in at.
Only thing left is that there were two cdi options also along with the stators. Possible if you look on the back of yours you can tell what part number. Either 3085639 or 3086982. May or may not be marked,but something strange is going on. Worst case scenario Ricks or Ricky stators can rebuild your existing stator if you haven't chopped it up too much.. Or try a different approach and hit the cdi also to see if you can get a matched system somehow.
