Belt Change
Old Mar 19, 2016 | 08:03 PM
thevarminthunter's Avatar
Default Belt Change
Hi could someone let me know when I should change the Belt I have a 2004
Polaris Sportsman 600 with 5100 KLM. I drive alone so would like to make sure I do not break down.
Thanks Hunter
Old Mar 19, 2016 | 08:24 PM
Kymco 450i's Avatar
Not sure how Polaris does it but I am assuming things should be same as my Kawasaki. In my service manual they had specs on the drive belt, such as width and deflection tolerances. I would take the cover off and check the belt dimensions. At 1600 miles I went ahead and put on a new belt and saved the old one as a spare for an emergency. The old belt was still within specs but just barely. If your belt looks good and falls within specs you should be good to go. Might want to consider carrying a spare for that just incase moment.
Old Mar 20, 2016 | 10:59 AM
TLC's Avatar
TLC
For the little cost and labourer in a belt I think you got you 5000k worth.
Here is a good video on changing one.
Old Mar 20, 2016 | 01:29 PM
greg74's Avatar
It varies how far an original stock belt can go. If the machine was used for heavy work such as plowing snow or pulling heavy loads, the belt will have more wear. Around 5000km or just over 3000 miles is about an average belt life though. That's about the point they wore out on both Grizzly 660 quads I had. If you do replace it, put another oem belt on. Many aftermarket belts are cheaper but oem will last longer.
Old Mar 23, 2016 | 04:28 AM
switzomatic's Avatar
Best bet is to change it and keep the old one for a spare. I've had my best luck with oem belts and cheapest prices are usually on ebay.
amalota
Feb 5, 2016 01:45 PM
amalota
Technical and How-To Articles
Feb 5, 2016 01:35 PM
shore
Feb 4, 2016 10:42 AM
jppaving
10
Jan 22, 2016 10:10 AM
keizer
8
Dec 30, 2015 12:26 PM
