Magnum Horror Story
Old Oct 14, 1999 | 07:13 AM
floodrunner's Avatar
There wasn’t that much pressure on the “spacer” I installed. The clutch / belt housing moves pretty easy if you try to tweak it in one direction or another. The guess is even with the small amount of pressure on the spacer it was the engine vibration and harmonics that used the dirt as a rubbing compound to “mill” the hole after 3-4 months usage. I believe the “spacer” was Lexan, a very durable plastic. I don’t think rubber would have had the same effect, although rubber might have worn through to the bolt underneath to cause problems.
FloodRunner, on the Wisconsin River
Old Oct 14, 1999 | 11:02 PM
sportsman's Avatar
this problem is really very common.i am surprised it has not been posted before. heat warps this plastic cover. the best way to fix it without buying a new cover is to take it off and find where it is rubbing, then take a heat gun and heat the spot "carefully". then push it out just enough to make it stop rubbing. most of the time you can only do the spot one time because it will make it thin there. beats buying a new cover.
Gwolf228
Feb 18, 2017 01:36 AM
01ssls1
Sep 22, 2015 06:50 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Sep 9, 2015 06:57 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
